walleyechaser
- Joined
- Jul 1, 2003
- 19
I have replace one switchbox because 2 and 5 were not firing. All of the plugs are now firing when grounded to the engine.I have replaced the fuel hoses back to the tank. I have rebuild the fuel pump and new floats and needle and seats.<br />I have checked the resistance of the stator with the following results red or red/wh to ground 143 ohms blue or blue/wh to groud 6350 ohms. Bias resistance to ground 13500 ohms and 14500 ohms. I have 3-4 psi pressure when cranking on the fuel pump. The timing is 1 degree at cranking and 20 degrees at WOT. All of the coils check ok with resistance. The stator wires to the rectifier read 0.8 ohms. Where do i go from here.
