kenburkeen
- Joined
- May 14, 2010
- 2
Hello all, I am at a complete loss on getting this outboard running. I initially thought it may be a bad stator. It passes the ohms test according to specs from CDI, but not the repair manual. Here are the numbers:
blue to blue/white 6000 ohms this is within the parameters on both CDI sheet and manual
red to red/white is 120 ohms cdi says it should be 60-150 but the manual says 56-76 ohms
I have disconnected the rectifier and spark did not return
I disconnected key switch and attempted to remote start, but spark did not return.
I disconnected the black w/ yellow kill switch wire but no luck.
I doubt every coil went bad at once, but this problem is driving me nuts.
Flywheel looks good.
Any help would be GREATLY appreciated!! Ken
