'84 Starcraft Alum. Crack in splashrail - need ideas for protection.
tinrunner2
1984 Starcraft Mod. Vee Bass Boat developed a crack along the outer edge of the splashrail (see pics). I've had it welded, but I'd like to cover both sides with something for a protective cushion. I'm open to suggestions - I don't know if keelguard would be flexible enough to cover it the way I want to - and it's expensive!.
What ever material I use would need to be approx. 3" wide by about 12 or 13 feet long (no need to go much further than that).
Suggestions & ideas much appreciated!
Thanks, guys!!
Pics are at http://s1113.photobucket.com/albums/k515/gbapperson/1984 Starcraft Bass Boat/
tinrunner2
Re: '84 Starcraft Alum. Crack in splashrail - need ideas for protection.
I'm thinking of masking off the hull above and below the splash rail & using spray-on bed liner. Two or three coats should give it the protection and cushion it needs.
I'll let y'all know how it works out.
Bob_VT
Pictures are not working.
Do not "cover" problems and please do not use bedliner. It will lead to nightmare future problems.
Welding is the best way to repair a crack....... next would be a metal patch riveted in......... and for small cracks or imperfections the last would be JB Weld (which does not offer strength).
tinrunner2
I've already had the crack welded; it's fixed. I'm considering something to cushion the edge splash rail.
