This past weekend I was running at WOT and had a power drop. It was as if I had pulled back to half throttle. I had my son to pump the primer bubble to see if that may help, no change. After I stopped the motor was idling rough and wouldn't even put the boat back up on plain. I checked for any signs of loose wires and/or fuel leaks and found nothing. I'm thinking switch box gone bad with the tach not working. Dose the tach connect to one of the switch boxes?
The motor has a new stator and I rebuilt the carbs about four weeks ago before the new stator. The motor did stumble once earlier in the day but picked right back up.
