Auxlarry
- Joined
- May 21, 2010
- 304
I think I created a monster!!
My engine hadn't been run in a year or so and when I got it all prepped (including new water pump) it only fired up on the right hand bank of cylinders. I did the normal trouble shooting, power pack and coil swap and had the same results. Well, the wiring under the cowl looked bad, cracked insulation, etc, timer wires were all nasty as well as the stator. I decided to bite the bullet and replaced the timer base, stator and both power packs with all new CDI parts. Looks great but guess what? Still have the same issue, no fire on the left bank of cylinders. What might I be overlooking? I cleaned all the grounds, new batteries (it turns over nice and fast) and fires right up on the right bank ( cyl. 1&3). I need some help on this one folks!!
I am getting fuel! Part of the prep was to rebuild the carbs but I have no spark on left, great spark on the right! (with spark detector).
Thanks,
Larry
Thanks,
Larry
