Alright first things first. I have replaced the water pump and have everything put back together and of course it doesn't pee. I rechecked the tell tale disconnecting it from the block and I can blow through it. The only thing I can think I could of screwed up was while I was reattaching the lower unit was getting the water tube and the grommet to sit back properly. My question is there a easy trick to get the water tube and the grommet together? Reason I say this is because by the time I get the tube close to sitting in the grommet I couldn't see. Because the lower unit and motor were basically back together.
