chipster427
- Joined
- Jul 14, 2012
- 15
Ok, I have what I think is a 1985 25HP Mariner. The only markings that I can find are on a freeze plug in the case. It reads 001185, and there are Yamaha stamps on both the case and the head. Is there any other way to determine year and model?
Now the Prop, It has a 9 7/8 x 10 1/2 on it. When I look those numbers up all it pulls is a prop for a Yamaha 30HP, and when I use something like Prop Wizard, these measurements aren't even an option for the Mariner. I'm just trying to fit a Prop with good all around performance on it. I don’t know what the current setup runs like(speed, RPMs @ WOT) because I am currently working on the boat interior and just got the motor running.
Also, I am still trying to figure out the measurements of props. I am guessing that the first number is the diameter and the second is the pitch. If that is the case, could I go with a 10 x 11, seeing how the measurements are so close? Or, Is it just going to have to be one of those things that is a Test N Tune?
Details, best I can:
14' Flat bottom Aluminum (I believe it is a MonArk)
Going back all aluminum guts, unsure of actual weight
Planning on adding Beavertail Floatation Pods
Main use is going to be duck hunting and some fishing, so there is going to be some weight to it/ in it
Suggestions please.
Suggestions please.
