hey guys, I have an 85 merc 9.8 el (sn A113176). i just got this motor a month ago in non running condition. changed waterpump/impeller, and rebuilt the carb. so I went to test start it today, and the electric start doesnt work. I got the engine running with the pull start but neither the button on the motor, nor the control key would start it. The "stop" button on the engine does however work, as well as the "stop" on the controls. So I thought my starter was bad, ripped it out, and tested it with battery charger and it works fine. So where should I look for the loss of power, can the button on the actual motor go bad? and what should i check from the remote key start side?
and rather then start another thread ill ask this on here too, when I did get the motor running it looked as if water was comming out of (around) both the spark plugs. that is a water jacket cover correct? and there should be a gasket behind it that just needs changed? how big of a pain is it getting that gasket changed?
thanks so much for all the help guys! I search for what I need to know, and there is a ton of info on here! But, wasnt too sure about these two questions.
Brian
Brian
