reelfishin
- Joined
- Mar 19, 2007
- 3,050
I picked up a used 1985 Evinrude 9.9, (E10RLCOM) which came as a bonus with a small boat and another motor, the owner said that he had given up on it and had bought the motor that is currently on the boat now.
The problem is that it will only start in gear and will only idle in gear. It stalls when put in neutral, but it does however run at higher RPM's in neutral. It looks to be a pretty clean motor, pretty much all original. It runs good in gear, so I figured that the carb is probably not the cause of this, when you shift to neutral, the RPM's drop and it dies. The only way to keep it alive in neutral is to shift it there with the throttle open.
It dies below what I would guess to be about 2500 RPM or so in neutral. He had several receipts for carb work and even a new carb, as well a new water pump kit. It also looks like they replaced the stator, and the entire ignition system.
It has 117/115 psi compression.
It has spark in neutral when it won't start, but not even a gasp. When I put it in gear, it fires on the first pull and goes along just fine on the water.
It does have what I would call a weak tell tale stream, but it doesn't overheat and I did check the pump and it looks brand new. The block and head is warm but not hot after a few mile run. Nothing changes after it's run a while either. It starts good hot or cold.
The lower unit is clean, no metal and turns freely in neutral, so I don't think it's a binding problem shutting down the motor. The prop was pretty edge battered, but nothing major, just showing signs of shallow water use.
I just got this so I really haven't gotten too deep into it, but just figured I'd get some input here before I mess with it this weekend.
