CamaroMan
- Joined
- Mar 18, 2016
- 330
Took boat out for a test.. set pri pickup at 10 degrees ATDC.. verified carbs all 100% closed at idle.. warmer it gets the worse it gets..
idles, sneezes - now and then it stall and fires up easy and sometimes struggles to restart..
At one point I felt the sneeze blow back thru air baffle against my hand while i was trying to tweak the timing and carbs to see if there was a sweet spot. I guess this indicated bad reeds??
I found an entire reed plate with carbon reeds used for 80 bucks - any thoughts?
Something else I can check? All the small hoses between carbs / etc are in good shape. I rebuilt the carbs 5 months ago-..
