Replaced VRO pump with replacement kit 6-7 years ago
Cleaned Carbs and replacement kit 6 years ago w/ minimal use since
Use Seafoam on about every fill up
Cold Compression test: 95,83???,93,93,93,90 (just checked)
6 years ago compression was all between 80-85 (wondering if Seafoam made a difference)
I have had problems with this motor for the past 8-9 years. I continue to think its a fuel issue, but I'm just not sure. Sometimes it runs like a champ, and then half the time it bogs down at WOT. Sometimes I can save it from dying, but other times I can't. Once it does this, I can't get it to power up all the way at WOT. Sometimes I can run it half way after this happens. Other times, I have to idle back in. I've had days where it does this, then I go out the next day and it runs like a champ again. I just don't get it. I use to have problems with it planing out, but haven't lately (I used to think my prop was part of the problem).
Any ideas? Also, would my one cylinder in the 80's be part of the problem?
Please help! Thanks!
