85 Evinrude VRO replacement options.....
Luna Sea
I have a 120hp EL120TLCO and I've seen plenty of non VRO fuel pump talk on this board. But I've seen price talk range from $45 to almost $200. Anyone have a part number for one of the inexpensive ones? And do these need to be bracket mounted and pulse line driven? I know on my big blocks I just had an inline electric canister type. Can these be used? Know they're affordable enough. Happy Holidays everyone! <br /><br />PS Got 12 days off from work, no forum for a while, and I thought yesterday was bad. :D Gonna log in over girlfriends though and maybe order new pump to go with new carb kits that I ordered. :D
Joe Reeves
Re: 85 Evinrude VRO replacement options.....
Luna.... I do have one new non warning type VRO left in stock ($40). This type VRO is very easily converted to a straight fuel pump by simply plugging the oil intake line. This allows you to simply install this type VRO into the present VRO bracket, then premix the oil with your fuel. If interested, contact me at ReevesJ32@aol.com.<br /><br />The procedure for doing away with your present VRO system is as follows:<br /><br />(VRO Pump Conversion To Straight Fuel Pump)<br />You can convert the VRO pump into a straight fuel pump, eliminating the oil tank and VRO pump warning system, but retain the overheat warning setup by doing the following:<br /><br />1 - Cut and plug the oil line at the engine so that the oil side of the VRO pump will not draw air into its system. Trace the wires from the back of the VRO to its rubber plug (electrical plug) and disconnect it.<br /><br />2 - Trace the two wires from the oil tank to the engine, disconnect those two wires, then remove them and the oil tank.<br /><br />3 - Mix the 50/1 oil in the proper amount with whatever quanity fuel you have. Disconnect the fuel line at the engine. Pump the fuel primer bulb until fuel exits that hose with the tint of whatever oil you used. Reconnect the fuel hose.<br /><br />That's it. If you want to test the heat warning system to ease your mind, have the key in the on position, then ground out the tan heat sensor wire that you'll find protruding from the cylinder head. The warning horn should sound off.
Luna Sea
Joe, I'll take one, sent you an email but I'll be out of work for 2 weeks. Please send address info and amount needed to DaileyPickles@aol.com,(girlfriends), title it "To Mike" I'll mail you a check. Thanks again
ob
LunaSea, Joe is offering you a very good deal.Particularly for one that will make up to your existing bracket.Jump on it.He's a very straight shooter and the part I ordered from Joe was packaged well and arrived timely in pristeen condition.
Luna Sea
Joe, Merry Christmas, I'm at my girlfriends, daileypickles@aol.com, sent you an email friday (?), please email the info I need to this address so I get a check to you to for that pump.
miloman
Glad to see that we are back on the honesty track and honourable guys are doing business here
