85 Force 125 outboard on 85 Bayliner 1900 body very, very hard to steer. Disconnected steering cable from motor and it turns freely. Pushed motor back and forth and it was very difficult to move from side to side. Greased all fittings and no grease pushes out of top of king pin housing, plenty pushes out of bottom. Also, it looks like there is a spot for another grease nipple in the housing, but that there was never a nipple put in. Have sprayed WD-40 on washer? that is between king pin housing and bottom of motor housing, which frees it up a bit, but still leaves a lot to be desired. Is there a flaw with this motor that a grease nipple was missed, and if so, can it be drilled in? Or is there another way to get in there without removing the entire power head? I have about 4 hours in this to no real avail.<br /><br />thanks,<br />CC
