Hello everyone, I am hoping some can help. I inhereted a 15ft Runabout with an '85 50HP Force outboard from a brother-in-law. The first time I took it to a lake the RPM did not sound normal at WOT, and the boat ran slow with 4 people on board. I am a bit of a mechanic but not so familiar with 2-stroke let alone an outboard motor.
I browsed on the web and found a website with blown up parts manual and found that this engine has a set of contacts to trigger the spark plug coils below the flywheel. I purchased a shop manual and found the contact set and plug settings (gap).
Now the problem... I am shearing the woodruff key on the Flywheel, only after a minutes of test run with the engine! I am on the third key... Is this because the flywheel nut is not torqued to specs?
Any help would be highly appreciated.
