85 four winns santara prop
Myride85
3.7l 190 hp I4. Just bout this boat a few weeks ago. Took it on the water for the 1st time Friday. 2000rpm max 25 mph was all it would do. 14.5x18 4 blade prop (it came with it). I know that needs to go. Can not find a recommended size I need for this boat. Haven’t tried the fuel line yet for collapsing. But this thing is a dog. Need recommended size prop.
think the 4 blade is keep this thing under rpm?
GA_Boater
Have you checked/tested compression and spark. The prop may be fine when the motor is running right.
Moving to the Mercruiser section.
Myride85
#1 130psi
#2 102psi yes a little low
#3 130psi
Can not get #4 plug out
Ayuh,..... Welcome Aboard,.... At 100 psi, that's a dead cylinder,......
I'm also guessin' the fuel system is all boogered up,....
Alumarine
Are you sure your tach is ok?
25 mph at 2000rpm doesn't seem right.
Did you check that speed with a gps?
Myride85
That's what I'm afraid of. The dead cylinder. I tried it 2 times to make sure cause I can't get the hose in all the way.
Myride85
When you say the fuel system is boogered up. What am I looking for? Fuel line collapsing? Scum?
Myride85
Correction on the compression check all plugs out
#1 155psi
#2 120psi
#3 120psi
#4 135psi
Butterflies in the carb are opening full throttle.
Oddly enough, I checked #3 compression yesterday. Put plug back in and found that plug snapped at the ceramic. Hmm
Myride85
Sorry for the multiple posts here.
But trying to get as much info out as I can
Retested compression again
#1 140psi
#2 120psi
#3 120 psi
#4 125-130psi
Myride85
Another update.
I pulled the fuel filter. It was the old style ceramic filter. Maybe? Soon as a store is open will be getting one.
