A little background info. The motor is a 1988, the gas tank recently filled with water, got bogged in the lake, the engine did not submerge but with the tank being completely full i'm sure some water made its way into the engine. Anyway that was about two weeks ago, since then i've cleaned the carbs and all fuel lines, filter, siphoned all gas, added new gas, etc. The boat will crank up and idle for a few minutes and then die out. Choke it and it cranks back up, idles, and dies out(sometimes with a pop or two). If I don't choke it the engine won't turn over. Once it is in idle if I put it in gear it tries to get going but then dies out again. It is my guess that there is not enough gas making its way into the engine since I have to choke it everytime to start. Any ideas as to where to look next? Everything from tank to carbs(3) have been taken off, checked, cleaned, and replaced along with any lines coming/going from the carbs and fuel separator.
