harrykleinsasser
- Joined
- Jun 18, 2004
- 21
I just bought a 1986 or 1987 (not sure which) 85 hp Force outboard and am installing it on a homemade boat. But when i tried to crank it for the first time. The starter motor only just manages to turn it over and I noticed smoke billowing out of the engine. It looks like the black (Ground) wire between the battery negative and the strip with all the other wires that you plug the control wire into has melted its insulator. The same thing happened a second time what is up? Could someone help? Thanks
