beachcraft
- Joined
- Apr 16, 2002
- 23
I need to find out why my voltage regulator keep burning out.<br />I check the AC voltage from the stator ouput at the AC input of<br />the voltage regulator is around 40 to 65 VAC at low to high RPM. <br />Does this is a normal range?<br /><br />I could get 15VDC from the regulator w/o connecting the output of<br />the regulator, but if I connect to the load, it will heat up and burn out.<br />The current is around 1 to 4 amp when charging. My engine is running<br />fine w/o charging.<br /><br />Please help. <br /><br />
