85 Hp evinrude with full throttle no power then after about few seconds you are
pillatzki
Lets see it is a 1972 85hp evinrude replaced new spark plugs correctly gaped, new plug wires, new Dist cap, new points,new fuel pump,new fuel line, rebuilt both carbs, New battery,new battery cables. to start it you have to squeeze gas bulb a few times till it gets hard,you turn it over nothing, you prime it by squirtting a little gas down carbs a put choke on starts up fine idles great give it full trottle no POWER after a few seconds your off like a bat out of hell. any ideals Thank-you :confused:
mrc
Re: 85 Hp evinrude with full throttle no power then after about few seconds you
Syncronize the carbs with the ignition advance.
pillatzki
How do you do that also it sure eats alot of gas
The Marine Doctor
Sounds like the choke is not working properly for starting.<br /><br />Clean the carbs up or adjust them for the bogging.<br /><br />TMD
pillatzki
how do you adjust them i have no idea any help would be great
The Marine Doctor
There should be some small screws on the carbs. Flatheat screws. Head size about 1/4 in.<br /><br />Turn them counterclockwise 1/8 of a turn.<br /><br />TMD
mrc
I suggest you obtain a OMC service manual for the<br />engine. It explains the syncronization procedure<br />with pictures and diagrams.<br /><br />Mike
oldboat1
I agree with the previous posts, but think about adjusting your starting procedure. Bypass the automatic choke by pulling the choke button all the way out. Pump the bulb until it's hard (or you're reasonbly sure that gas has been pumped through to the carbs). Open the throttle as far as you can (all the way if the safety switch has been broken or removed, then back to the fast idle starting position). Crank it over for about 10 seconds. If nothing wait for 10 or 15 seconds and try again. If she pops but doesn't fire (or sounds like she wants to take off), push the choke button all the way in (choke off), and try again. etc. etc.<br /><br />and it doesn't hurt to talk to her a little....
