85 hp merc no power in gear
jrfich
my engine runs fine in neutral.put it in gear and it dies out.any ideas.it is a 78 or 79 thunderbolt.i was told the exhaust plate or plates were bad? compression is good in all cylinders and i see no water leaking anywhere.egine sat for a couple of years.had the carb cleaned and float and seal replaced.help please!
NathanY
Re: 85 hp merc no power in gear
All the engines that I have ever seen with this problem, always end up being a fuel related problem, even though the carbs and what not were just cleaned and what not. <br /><br />I would say that the carbs are still not either clean, or set right.
jrfich
Originally posted by Nathan in Arkansas:<br /> All the engines that I have ever seen with this problem, always end up being a fuel related problem, even though the carbs and what not were just cleaned and what not. <br /><br />I would say that the carbs are still not either clean, or set right.
jrfich
thanx for answering will have it checked out
Gus Mortimer
has it been like this since getting it out of storage? Was this your motor before sitting a few years, if so was it running fine when you stored it? did you get a reason why it would be leaking exhaust plate i.e. steam cleaned plug etc.<br /><br /> The reason I ask this is, I ended up with a motor that had been sitting for 5 or more years and had similar problems. mine ended up being ignition.
