firemann2003
- Joined
- Aug 26, 2006
- 58
Got new rings and leaf valves. Trying to remove powerhead and it won't let go. Removed 2 bolts and nuts under the front, the two just under the exhaust housing in the back and the six long ones coming up from the bottom, the problem is that the two back ones, of the long ones, broke off at the head of the bolt. The powerhead will now not lift off. Can the front crankcase come off without removal of the powerhead? I'm assuming it can't. Does anybody have any ideas how to get the powerhead to come off? I will now need to cut those bolts off and remove them from the holes in the block. The front of the powerhead will lift up a tiny bit but the back will not budge.
