Re: 85 johnson 150 oil injection
No its not easier, but it gives many piece of mind, or if you have problems it is much simplier to disconnect and mix vs buying some high dollar pump. Untill it gives problems i would leave it be. You have to measure and pour it in guessing how much gas you can put in and then measuring that amount of oil in then chase it with gas.
It is much easier fueling up the VRo boat vs the no vro boat where i have to premix.
