twocyclemania
- Joined
- Aug 10, 2010
- 505
Just finished this motor (new rings - honed bore), carb rebuild, new coil and new impeller and head gasket. The head was super clean and the area inside the exhaust cover also. Seems to run well in my test tank but I believe it's overheating. I sprinkled water on the head and it sizzled. It is putting out water mixed with exhaust at the four holes on the lower leg. The pump itself looked almost new and I also replaced the rubber grommet at the top of the water pump. Any suggestions? thanks
