Re: 85 Johnson 235 Peak RPM
I can't tell from info available which prop is best. True, you do want WOT to be about 5500-5800 but IMHO, there is a bit more to the formula. If you are simply comparing the props without trimming up to max RPM just below the start of porpoising or ventilation, you might be comparing apples to oranges.
