I have a 1985 johnson 50 hp I bought for my mckee craft. The boat it came off of had flipped over during a tornado and port side powerhead mounting bracket had been broken. The engine has 150lbs compression both cylinders. I replaced bracket and cleaned carbs. Engine starts and idles fine. When I raise rpms up around 1200 the engine keeps raising rpms on its own without the carb lever moving. I have to shut off the engine to keep it from getting to high. I'm thinking I might have a case leak letting air in and leaning it out. Any Ideas? Thanks!
