webnetxpress
- Joined
- Apr 14, 2004
- 21
just trying to get a boat in the water for the first time in about 2 years. I've been going through it and replacing all rotted out or old components. I replaced the impeller this week. yesterday I started it up (in the driveway with the water muffs on) and began to set the timing, dwell, idle, mixture, etc. I finally got it running good but then it seemed to start to overheat. I'm not sure if it was because the overflow tank was empty to start with? or it was just plain old overheating...<br /><br />Anyway, what is the normal range of temp for this engine?<br /><br />I have plenty of oil pressure, a full coolant tank, a new impeller and no noticeable leaks anywhere. <br /><br />So, if it's overheating what would I look at- the thermostat?? <br /><br />Thanks, Dave
