FirstTimeSeaLegs
- Joined
- Apr 10, 2013
- 13
Hello all,
(Please, if this post/topic has been discussed for the year/make/model of my outboard, I apologize as I did not see it when I searched the forum and this may be deleted)
I Bought a 1985 Bass Tracker that came with a factory installed Mercury 25HP XD on it. I have fiddled with running the motor on muffs, and as per norm, seemed to me at least, to run "okay". Ran a little rough at first but as it warmed up the idle would improve and eventually stabilize. Put into forward/reverse and tried to give it some throttle, and it would bog down and die. Restart the motor and repeat that process 2-3 times and it evetually would let me throttle up in both forward/reverse as long as I feathered the gas/throttle. All the above is while motor is on muff's.
Decided that I would just take it to the lake and see if it was simply something that I could "run out of it" while out on the water. After about 30 minutes of messing with it, I was able to get the boat off the pier and heading out into the lake. I twisted the throttle as far as it would go, the motor rev'd up some, but it was NEVER hitting above/around 2000ish RPM's. Now, the RPM's is just a best guess on my part, but based on watching videos of well running motors just like mine. Top speed was between 5.5 and 5.6 mph by GPS. Pulled the cowl off and tried to run the boat again, this time trying to pay attention to the throttle linkage and the opening/closing of the butterfly valve in the carburetor. Everything appeared to be opening/moving as it should with no binding etc, but no matter what I tried, I could not get the motor to run in the 5000 RPM range. Loaded the boat up and headed home after spending 3 hours on the water, accomplishing nothing.
Did some research and found several topics related to my symptoms possibly being a fuel issue. So that said, I emptied my fuel tank, replaced the fuel hose, cleaned both strainers/filters and then made up 5 gallons of fresh 50:1 fuel. Took the boat back out to the lake the next day and had a repeat of the same problems as before, very very poor performance/no RPM's at WOT. Filled a water bottle with fresh fuel and poked holes in the cap and tried spraying the fuel directly into the carburetor while holding the throttle at WOT. The RPM's never changed.
I am here in hopes that someone has come across this before or something very similar and may be able/willing to help. I tried to keep the story short and sweet as best I could. If more info is needed please let me know.
