Re: 85 tournament tx
awesome boats for the price, The side seems and transome supports are welded but if you look under the hull you should see a bunch of rivets so its considered a riveted boat .They didnt start all welded till much later.If your boats on the trailer you can check for loose rivets ,sometimes this is a small problem.My 1988 txs 17 is still bone dry after all these years.And hull thickness is about .070 . Good luck and enjoy!
