Hello All,<br /><br />I am new to this board and even though this is my first post, I have already learned alot from reading old topics back 3+ years. Thanks to everyone for all the great posts.<br /><br />I was given a 1970 Browing 18.5ft champagne hull with an 85hp '69 Johnson 85ESL69S about 1.5 months ago. Even though my family is full of boaters and fisherman, this is my first boat. The boat needs repair on the deck but overall is in good shape. I decided not to tackle the boat repairs until I made the engine run, since the only water the boat has seen in 12 years is rain!<br /><br />After jerry-rigging a non-original solonoid, non-original rectifier, replacing the powerpack with an ebay special ($35!) rebuilding the ignition switch, replacing choke switch, and chasing down wiring faults, I was successful in getting the motor to start last weekend. I only ran it for about a minute with the muffs on but I don't believe the water pump was working so I shut it down for fear of overheating. Compression about 120psi each cyl.<br /><br />Based on posts from this site, I have purchased an OMC original parts and service manual. I plan to replace all battery cables, solenoid, rectifier, plugs and perhaps the inner wiring harness. I also plan to replace the water pump assembly and renew the oil. <br /><br />The original owner ran all the gas out of the carbs before storing it and they appear to be fine. So, I was considering leaving them alone.<br /><br />I believe I am on the right track with this is there anything I have missed? Anything else I should do?
