85hp force 15 foot glastron bass boat, where to start?
mikmic2
I have a 1978 15' Glasstron Bass Boat. Two livewells, trolling motor, two batteries, and will likely have anywhere from two to 3 passengers at any time. Me and my son weigh about two hundred pounds, and my father weighs about 150 pounds. <br /><br />I bought this boat without a lower unit. So now that I have replaced the lower unit, I need to know where to start with propping it out. <br /><br />The motor weighs 250 lbs, the batteries and trolling motor would weigh another 100 or so. The passengers would be from 400 to 550 lbs. We usually carry a couple of hundred pounds of gear. <br /><br />With a full gas tank, and the livewells full, I would expect another 150 or 200 pounds. <br /><br />Having added all that up and coming up with a weight of 1000 lbs or so. What would the hull weight be? 800 lbs? It is a normal looking Bass boat from that era, just a little short at 15'.<br /><br />I would guess that fully loaded, we could be looking at 1700 lbs. Does this sound about right?<br /><br />I have been told by Mercury, that my 85hp, really only puts out about 80hp, because it is rated at the crank, and not the prop. <br /><br />So, does starting at a 15 pitch aluminum prop, sound about right, for a 1700 lb Bass boat with a 80hp engine? Or, perhaps a 17 pitch prop?<br /><br />I will have a tach to keep my RPMs about 5500 like it is supposed to be, at WOT.I just wanted a starting point. <br /><br />I will keep another prop around for those days, when the boat will not be loaded so much, but I will mainly be using it loaded, and wanted a starting point.<br /><br />What do you think?<br /><br />I was thinking about starting with a 17 pitch, because I wanted to get two different pitches, and I thought the 17 would work good when it wasn't loaded so much, and might just be good enough for when it is loaded. Then I would get a 19 for when it is empty.<br /><br />Or maybe 15 pitch when loaded and a 17 pitch when empty.
gatorred
Re: 85hp force 15 foot glastron bass boat, where to start?
my 15 ft Glasstron had a 19 pitch on a 80 hp Mercury wasn't bass boat
MWBROWN
I have a 1984 Bayliner Fish and Ski 1510 (16ft)<br />2 live wells, trolling motor, 20 gal tank.<br />It has an 85 HP Force that came with a 19 pitch prop. 13 in dia. It has been pitched to 20 when I had it rebuilt. Top speed went up a couple MPH. Don't know rpm's but with 4 people it would go 35 plus. Engine purrs at 25 to 30 MPH with good economy.<br />Hope this helps.
mikmic2
Thanks for the replies. This has got me leaning towards a 17 pitch to start out with.<br /><br />But would appreciate anymore input.<br /><br />Perhaps someone could post who has had a tach on their boat and tell me their weight and what rpm's it was running.
LubeDude
I think you are right on track! You just have to try it and see.
Ron G
First you really need a proper working tach so you can actually see what prop is better just listening wont cut it.Then see if you can borrow a 17p and try it,that will give you a baeline there to go by.
mikmic2
Yes Ron, here is what I stated in my first post.<br /><br />"I will have a tach to keep my RPMs about 5500 like it is supposed to be, at WOT.I just wanted a starting point."
