Kevin58145
- Joined
- Dec 30, 2007
- 14
Hey guys at the end of last season I checked my compression and if I remember correctly the numbers were 125-90-125, which bothers me. So today I got a new toy for the tool box(bore scope) and wanted to check it out so I pulled the spark plugs and by hand rotated each piston to BDC and put the camera in, The top bore looks good noting that cought my attention other than the carbon build up, The middle bore looks good as well just has the same carbon as the top, The bottom bore looks pretty good there were a couple of questionable marks but the scope makes a business card look like its 1/8in thick and the questionable marks were way less .
Also the bottom bore is a .020 over piston the top two cylinders apper to be stock with no markings is this normal for only one cylinder to be oversized?
As for the low compression on 2nd cyl could this mean that the rings need to be replaced?
I've heard of decarbing the motor but have never done it, Does it work? and could it be the reason for 35psi differance between cylinders?
Im comfortable doing my own engine work although this is my first outboard 2stroke (well 1st 2stroke ever).
I've built several small block chevys from the ground up but have never touched a 2 stroke till this boat
by the way its a 1988 85hp force
since I got it 3 years ago I've changed the spark plugs a couple times rebuilt carbs last year, changed the gear lube every season and the impeller last year and a fuel pump kit,
What other maintainance should I be doing I wanna get it running top notch before going out this year.
thanks in advance I hope I get lots of replys.
