I have two problems. First, does anyone know if there is any other way to find the year, model and serial number if there is not an ID plate? The plate on left transom mount bracket is gone. I tried looking in engine compartment but all i see is "made in USA" and a circle with "86" in center. Can model be determined by any other part numbers? I do know it is an 85HP. Second, the left transom mount bracket needs to be replaced, due to severe corrosion. I found a power tilt/trim unit on EBAY that came off a 90HP. It includes both transom mount brackets. Does anyone know if the the brackets off the 90HP will fit on an 85HP? I would probably replace the entire tilt/trim unit. Any help would be greatly appreciated. Thanks
