1985 Merc 25XD s/n A162934.<br /><br />Dropped a cylinder last fall. Chrome bore is beyond repair.<br />Replaced block/pistons with a USED short block (block, crank, pistons, reeds). <br />Motor starts & runs. Wont idle down. She dies before I can get her into gear. Timing is suspect at idle thru wot.<br /><br />Clymer manual is not terribly clear on timing/carb sync but I think I can follow it ok. <br /><br />I am hoping to get her going then take her to the lake & beach her (20 toon boat) to set wot timing (dont have access to a test prop). 55 gal drum is a bit small for running motor at wot.<br /><br />Can I set low speed/idle timing and idle rpm with carb before setting wot timing or does setting wot timing throw thelow speed settings off. <br /><br />Is there a procedure for statically timing this motor or does she have to be running? <br /><br />Any other pointers/thoughts/suggestions appreciated
