werdna9691
- Joined
- Jun 6, 2003
- 15
i have a 19 foot trophy f/s with 125 hp outboard<br />i ran it a few times on the lake and the tilt trim went south i still was able to run it without the tilt trim although it was hard loading and unloading it. it ran about 40 mph<br />when trimmed up and about 35 mph without the tilt n trim. i was pulling into the boat ramp<br />parking lot and the motor bounced off the motor tote and i drug the prop on the payment. i filed the prop on site as best i could and took the boat out anyway. we were having a small club tourney that day. i ran the boat out and the best i could do was about 10 or 12 mph. when the tourney started i went out behind 3 other boats and the boat jump up to about 30 mph.<br />i shut it down to fish an island then when i went to leave the boat would only go about 10 or 12 mph again. i bought a new comp prop and repaired the skeg. took it out today and the boat was still slow. if i put it in neutral<br />and rev the motor it sound fine then you put in gear and take off and the engine justs bogs down it jumps and misses at about 3/4 throttle<br />like it wants to take off but it wont it juts putts along do you have any ideas on what might be the cause? (ive replaced the plugs)<br />(just and afterthought:when you put the motor in neutral after you ran for awhile then you can <br />push the throttle all the way open and it wont<br />reach any kind of rpm could it be something to do with the throttle linkage
