I have been doing some troubleshooting via the OEM manual but no luck. 140 Evenrude 1986 looper I had a charging issue when I got the boat it had no tach and the previous owner had reversed the battery cables. I replaced the rectifier and power pack and that solved it.
This time I changed out the controls with same but better condition ones and in the process the fuse in the motor blew somehow. I dont think I did anything wrong. The fuse was old and rusty. I replaced the fuse connector, fuse, and the starter solenoid at that time. Since then I have no charge at all just battery power.
What would cause the fuse to blow and what part would that likely effect? What would be the likely part that would allow the tach to work, but not the charging system? The stator looks fine seems like something happened when I redid the controls. Motor runs and starts fine has tach but just no charging. Would the power pack or the rectifier blow in a way the tach would work but the charging would not? Any pointers or what to check for would be a big help right now.
Thanks
Thanks
