imported_Warren
- Joined
- Apr 7, 2003
- 261
Took out my plugs the other day and noticed a lot of carbon buildup on the plugs and inside the head. How and what do I do to de-carb this outboard? I want to get as much as possible out of it. I heard that you need to have the prop in a trash can because after you use the decarb spray your supposed to run the motor under load. Is this correct? Do you think I should just take it to a mechanic ($60 an hour), or attempt this myself.....Thanks Warren
