Hey guys. I've done a bunch of searching/reading the archives on this. My problem is, had the Wellcraft 192 w/Mercruiser 170/470 out yesterday. Started up cold fine, fished for a while, ran around for a while, shut it down for about 5 minutes and she didn't want to crank over fast enough to start. Starter was hot from motor heat. Let it cool down for a little over an 1/2 hour, cranked up quicker and fired up no sweat. Back to the dock after running at a good clip for about 10-15 minutes, shut her down and tried restrating, very slow cranking and just about stopped, and no start. Got home 1 hour later, cranked quick and started right up. Are these marine starters badly affected by all the heat generated in the doghouse and have a short lifespan? I'm thinking my problem has got to be the starter as i've read a bunch of different posts on this and have already done most of what have mentioned - new battery, new thick + & - cables, cleaned ALL connections. It's almost like when your timing is off or when you try to crank a high compression motor, but only after she warms up. Cold starts cranking is quick. Also, oil clean, fresh and not heavy viscosity, Exhaust bellows replaced recently and no water leakage, Engine temp runs nice even at WOT for a while - 165deg, timing checked OK, stator still in place and doing it's job properly. I've basically got it narrowed down to the starter, in my opinion, but would like to hear from the more experienced. Am i thinking in the right direction? If it is the starter, what's the best one to get that would last the longest? I think i had this one rebuilt about 2 years ago. Just seems odd that it would crap out this quickly...but it was very hot to the touch after running the boat around for a bit and it is enclosed unlike an auto starter that get air easily...Thanks much in advance for any help.<br /><br />- Jersey
