prudenceisland
- Joined
- May 29, 2009
- 33
i have a general question here.
im trying to reassemble the carb and im stuck because i am not sure which way the float pin rests on the metal arm that connects the float to the motor. i am assuming that the pin should go rubber up. meaning the rubber tip should point up into that fuel port thingy. im not an expert and im learning i appologize for the confustion.
another thing is that piece of metal that connects the float to the motor has a small hole that looks like the pin would fit into it perfectly. however when i reattached the float with a fabricated axel, the holes don't line up.
helppppppppp
helppppppppp
