86 40hp Johnson 1/2 power with two people
Gantz6
motor has new tank lines and filter, carbs rebuilt, timing plate replaced, fins great to plane with one person, but add another and it won’t get past 1/2 throttle power just sounds like it’s working harder. Propeller has worked fine in past
Start with a compression test.------Or perhaps the boat is full of waterlogged foam ?------Seen that many times.
Compression is not encouraging.----Test with another gauge perhaps.----Checked flywheel key ?
