Full story; I went out with 4 people in our 15' MFG 'glass boat. Engine was behaving just fine. It's de-VRO'd, running 40:1 premix. We trolled out of the harbor and slowly moved away from the small sailing craft nearby. A brief full-throttle push to see how long it takes to get up on plane with a 'full load', responds nicely and got up on plane for ~30 seconds. Throttle down and turn around, cruising along at about 2/3 throttle for about 10 minutes taking in the sights. We're plowing but high in the water, engine sounds happy. 2 miles out from dock I push the throttle open again and I feel the engine bogging. I pull back and the RPM starts to drop. Boat lowers in the water. Fearing a stall I open it back up again and the engine is maintaining RPM but struggling. Probably 5mph, WOT. Took a good 20 minutes to get back to dock. Once there I throttled back to idle it actually maintained idle but it was clearly operating on one lung.
The carbs were clearly leaking around the bowl gaskets and poured fuel when I tilted the motor up to launch/recover. I figured some varnish had come loose and plugged something in one carb. Carbs were removed and sat in cleaner for 3 days. Rebuild kits installed (no floats were included but buddy said they were perfect). Floats were set equally at 3/4". Fire it back up on muffs and it sounds like it's running ok, but there's occasional miss fires. Responds to throttle snap nicely, but definitely cutting out at idle. Here's the fun part; Pull top plug wire, engine nearly stalls. Bottom plug, barely any difference. 150psi compression top, 135psi bottom. Bottom plug is wet with gas, top is dry, both electrodes are cold to the touch. 115? @ upper plug, 100? at lower plug. Found 243 ohms secondary resistance on both coils. Swapping plugs and/or wires did nothing, top cylinder still doing all the work. Noticed fuel spitting from carbs at idle with the silencer off. Engine seems smoother at idle when I apply a little pressure to the fuel bulb. Also noticed very little water from the telltale.
Here's a 2:30 video of it running. Any opinions on this? I don't want to get out on the water again and have it fail on me again.
Edit; at 1:50 the RPM comes up. Buddy had lifted the high-idle arm a bit, then lowered it. It was not a flare-up.
