86 50hp, 14 foot, seems slow
dkonrai
1986 force 50, on a bayliner 14 foot.
rebuilt carb, new fuel lines, bulb, fuel pump, coils, plugs.
now the problem,
i changed the prop, went with a flatter pitch and now it seems slow. i went out on a windy day and it seemed slow to get on plane. the gps showed a top speed of 18mph.
i noticed at wot, the buttlerfly went past mid way and it bogged (butterfly went past midway and into a closed position)
maybe timimg? i have not checked the points, could this be it?
runs great, idles great, just seems to lack top end.
dino
jerryjerry05
Re: 86 50hp, 14 foot, seems slow
Do a comp/spark test.Then check your linkage.The butterfly can actually go past half way but not to closed.
Going from say a 15p to a 13p should raise the rpm.
What rpm are you running with the old prop and with the new?
No tach, hook up something You can't tell true performance without one.J
dkonrai
i have tried a number of tachs, but still havent found one that works.
the compression is good, i am not sure how fast the boat should be going?
dino
my guess is a linkage problem.
