I installed a larger motor on my 17ft Mako. I'm looking at the manual and the pictures seem to have the two upper engine to transom bolts going opposite of the lower. Bolt to the inside nut to the outside on the upper, reverse on the lower two. It also mentions using marine sealant on the shank but not the threads of the bolts. Do I use 3M 5200, or is there another recommendation. I haven't put the boat in the water yet, so no harm done. Just want to be sure that I do not get water in the transom. Any input would be appreciated....<br />Tony
