86 alpha drive threaded shaft for trim cyinders size?
lime4x4
The long threaded shaft that holds the trim cylinders at the end of the leg. They one u have to remove in order to remove the drive. What size thread is the treaded part. The nut stripped and threads are damaged. They look to be 7/16-20. Is that correct?
Re: 86 alpha drive threaded shaft for trim cyinders size?
Ayuh,... 3/8" fine,... 24 pitch I think..
lime4x4
incase anyone else needs to clean up there threads on that shaft there
7/16-20
