86 Bayliner Capri bowrider fixer upper
kmelville2
I picked up an 86' Bayliner Capri 18' bowrider with a 125hp Force outboard.
It needs plenty of work but I am especially confused on all the wires on the right side of the boat when there is a strap for a battery on the left side.
Is there a junction box I'm missing? It looks like the biggest wires, probably for the starter will reach over to the left side but the mess of other wires won't. I have the wiring diagram and can eventually figure out what wires go where but I would love some help. Does any one have a picture of your boat and how this is supposed to look?
gcboat
Re: 86 Capri bowrider fixer upper
A quick question. Do you have a MBSS installed? If so, then there's a pretty good chance that the boat had two batteries in it.
It really is hard to try and decipher some one else's previous work. I'm just shooting in the dark. :eek:
Also, a lot of times the battery will be on the port side to offset the weight of only having one person - the operator -onboard.
Welcome to iboats. :D
kmelville2
Re: 86 Bayliner Capri bowrider fixer upper
I'm not sure what MBSS is but if it had 2 batteries wouldn't the wiring diagram in the manual show it?
Thanks for the response
johnny demo
Hi all
I just got a 1985 Bayliner Capri bowrider
Seems like the floor and stingers are bad,,but i guess the good news is that the volvo engine is still good, tags says its a volvo AQ125B, runs good and strong, however I did not that the trim motor was bad,
I started cutting the floor out, and diging the foam out( man, for me thats a job and ahalf.
can some one tel me what and how i should do this, and what order
1. how many gallons of foam do i need
2. how much glass
3 do i use mat or colth
4. can i use 2x4's for the stringer
5. do i use polyester resin or epoxy.
Also I an new to this sorry if i sound like a nut case
