Re: 86 bayliner capri steering ?
My misconception - sorry. Looks like now you can start by looking at binding cables, worn, frayed, etc. Remove the cables from the motor and see if there is any difference in the action of it all. If stll binding then you need a new steering unit or cable replacement. If it is smooth then check the movement of your motor. Don't know what kind of motor you have but there is usually a zerk fitting under the cowling to add grease. It's usually one or the other, unless the boat has been sitting for a while then they both might give you a fit.
Right now it's just trial and error on your part.
