86 Evinrude have a charging system??
knobby
Does anybody know if an 86 Evinrude 9.9 with electric start has a charging system to keep a battery charged or was that added later?<br />thanks guys.
OBJ
Re: 86 Evinrude have a charging system??
Knobby...if the engine came from the factory with electric start, it most likely has a charging system on it. Look on the starboard side of the engine for a little tin can mounted on a triangular shaped base. This is the rectifier. If you see this, then the engine has charging.<br /><br />If the electric start was an add on, it may not have charging as the charging system was not included in the elec start kit and had to be purchased separately.<br /><br />Hoped we've helped.
knobby
Thanks Jim, yep it's got one.
