86 FORCE 125hp bogs at WOT
pemberton5
Someone please HELP I have a force 125hp thats runs good at idle and 1/2 and even 3/4 throttle but at wot it bogs down and stalls. I have replaced fuel pump diaphram twice and check valve also hoses primer bulb and pulled pick tube from gas tank as well as cleaned the vent tube , new spark plugs carbs were gone rebult two years ago and still engine wont go WOT. any help is needed bad PLEASE !!!!!!!!!!!
bustermin
Banned
Re: 86 FORCE 125hp bogs at WOT
please give a little history, did this just start, or did you just start using the boat after it sat for the winter (or longer). did anyone work on it prior to it acting this way? did you just buy the vessel, if it was winterized prior to this hapening, what was done to winterize it and what was done when you took it out?
pemberton5
yes this just started i have had the boat for two years and ran fine except ! for an occasional die at idle i winterized boat and ran it twice this year when the problems began i getting ready to take to boat shop but darn the so expensive.i put the new plugs in it and checked fluids and greased zerts before takin it out plugs looked good i took out but replaced any way. then after couple trips when probs started and i put all the other stuff on.
bustermin
Banned
you didnt mention the fuel filters, have you changed those? also have you checked the fuel lines, are they sucking closed when you are at wot, just because they look good on the outside doesnt mean they are good on the inside.
pemberton5
yes changed screen in sediment bowl as well as new gasket replaced the glass in line filter too.???
Jabongans
I have an 87 Force 125HP with same problem. Two different mechanics told me my lower carburetor is bad - but neither can find the parts/replacement.
bustermin
Banned
did you look at the spark plugs, is it running too lean?
pemberton5
Crowley marine on internet has lots of parts i by lots there also try ebay. wat ahve you done to your motor to try solve prob mine is surely pi##in me off
bustermin
Banned
A white colored plug is caused by engine overheating. Failure to repair this engine will result in severe engine damage. Common causes for this are:
Incorrect spark plug (too hot heat range).
Low octane fuel.
Timing is not set properly.
Cooling problems, (dirty cylinder fins, no or low water if water cooled, low or no engine oil).
Carburetor air/fuel mixture is too lean (too much air).
Leaking crankshaft seals, no oil, base or head gasket leaks, or crankcase leaks on two stroke engines.
pemberton5
Low octane fuel.
I will look my plugs are the flat champion ul18v i think there is no gapping to them
Unbalanced
Sounds like a fuel delivery problem. WOT is where fuel delivery is at its highest. The fuel system seems like it's just not keeping up. Have you tried pumping the bulb at WOT? There could be a restriction in the fuel line or the floats aren't set properly.
pemberton5
yes at wot if we pump bulb boat runs fine but have tried out of another tank and does the same thing fuel system is not keepin up you are correct. dunno much bout carbs thats beyond me however i took it too boat dr guess ill see tired of jackin with it need NEW ONE !!
4runneradam
Did you figure this out yet? Mine started doing the same thing today. Worked fine the last time out, now it wants to cut out at WOT. I have a clear fuel filter and I can see its empty.
john from md
There are three check valves inside the fuel pump housing. If they are sticking it will give you those kinds of symtoms. They cost $5 each, two are easy to change, one requires some finesse.
John
87blf125
i have an 87 force 125 that did the same thing, it turned out to be the floats on the carbs were set to low, i reset them and have had no problems. give it a try, hope it helps!
