dkonrai
- Joined
- May 9, 2009
- 719
here is the motor i just got with my bayliner. its a 86 50hp.
question is this the rectifier?
coils look ok? it runs pretty good, but low idle its a little off. will try and clean the carbs.
whats the clear tubing for? i know its the outlet of the thermostat, but what is the purpose? i plan on installing a tell tale, first force ive owned.
i will say that the motor is well built, took off the carb and could not believe how simple the design, brass float, ease of installation of the carb.
if the motor is running and i take the leads off the battery and it dies, is this normal? i need to replace the rectifier, do i replace or install a regulator as well?
sorry for all the questions, but i am a newbie for the force. much easier to work on than my evinrude or merc.
thanks
dino
thanks
dino
