Tandarocks
- Joined
- Jul 20, 2004
- 6
I have a 86 125 Force outboard that i just got out for the summer. I took it out to the lake to make sure everything is working for my vacation and it ran great for about 30 minuetes. After that it started to loose power and hesitate at full to half power. I stopped the boat and noticed that it was running rough. The motor now seems to gallup and not run at a smooth idel. I had this happen before, not as noticible and checked the fuel filter/screen and it was clogged and after cleaning it, it ran great. This was checked this time and the screen was clear. I check the plugs and they all were the same as far as color and moisture content, so there dosen't seem to be a too rich problem. When I checked to make sure the spark plug caps were on tight the second from the bottom shocked me while the motor was running. I'm assuming that the boot needs to be replaced but could this be the cause of my problem as far as performance and smooth ideling goes? I also tried adjusting the carbs in both direction but this didn't cure the stumbling problem. Any help would be greatly appreciated. Thanks, Todd.
