If I put the trim up at all, the motor won't start. Gets a good crank, won't get gas. When I trim it all the way down, it starts, but blows smoke.
It also won't stay idling unless I rev the idle control constantly. It idles really rough even then. If I'm idling, and I put the trim up (trailering, shallow water) it dies every time.
Seems to run fairly strong at speed, but has a vibration during takeoff. Once I wind it out and run it 2-3 minutes, vibration stops and it runs fine.
I feel like the engine is flooding when I put the trim up without giving it throttle. Is this a possiblity? Would oil/fuel mix be a problem (it's oil-injected)? What do I check and where should I look? Thanks
